Router Collet adapters http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=14609 |
Author: | David Collins [ Tue Nov 20, 2007 2:39 pm ] |
Post subject: | |
I'm getting tired of having to buy $25-$30 1/8" spiral bits for my saddle routing jig just because I only have a 1/4" collet. Then of course 3/16" spiral bits are a pain to find. I'd much rather be able to select from a wider selection of end mills for much less, but they of course generally come with the same size shaft as the cutter. So what are the options? I would love to find a set of split adapter bushings like these, but for 1/4" O.D. I don't think I can get a 1/2" collet for the PC310, or I would just do that. A set of adapters would just make shopping for bits so much easier. Anyone know of a source I haven't found yet? |
Author: | Kent Chasson [ Tue Nov 20, 2007 2:49 pm ] |
Post subject: | |
I tried one of those to go from 1/4" to 1/8". The bit slipped and I haven't used it since. Maybe some are better than others or maybe I just needed to tighten it a lot more than I'm used to. But the concept of a collar inside a collet seems inherently problematic. Maybe others have had better luck? |
Author: | grumpy [ Tue Nov 20, 2007 3:18 pm ] |
Post subject: | |
I've been using 1/4" to 1/8" adapters forever. I have two of them, and soon get a third.... never had one fail or come loose. . |
Author: | Rick Turner [ Tue Nov 20, 2007 3:22 pm ] |
Post subject: | |
Ditto. They work fine. I tend to use Bosch laminate trimmers for small bits, Porter Cable 100s for medium sized 1/4" bits, and then a big honking Hitachi for 1/2" shank bits. |
Author: | David Collins [ Tue Nov 20, 2007 3:41 pm ] |
Post subject: | |
Perfect! I've been searching around through tool suppliers, and never thought to check a luthier supply house. It looks like they have both 1/8" and 3/16" adaptors, which is exactly what I needed. Thanks guys. |
Author: | KenH [ Tue Nov 20, 2007 4:50 pm ] |
Post subject: | |
I bought a 1/4 to 1/8 adapter from stewmac and also the spiral 1/8" bit too. So far I havent had any problems with it coming loose. What I would really like to have is a dremel-like flexible shaft tool that would connect to one of my laminate trimmers. Anybody know of one? |
Author: | David Collins [ Tue Nov 20, 2007 5:03 pm ] |
Post subject: | |
Ken, if you want a good flex-shaft tool, just get yourself a Foredom. It's an investment you won't regret in my opinion. I was actually a bit concerned about the risk of split collet adapters coming loose, though it seems if they were cleanly and accurately made there should be no problem. Sound like that's the consensus from everyone's experience here, so I'll be ordering one soon. I may try the StewMac one first, as I think I need to order a few things from them anyhow. |
Author: | grumpy [ Tue Nov 20, 2007 5:29 pm ] |
Post subject: | |
I get mine from LeeValley |
Author: | Rod True [ Tue Nov 20, 2007 5:35 pm ] |
Post subject: | |
Lee Valley sells them for less than 1/2 the stew mac price. That's where I got mine |
Author: | Rod True [ Tue Nov 20, 2007 5:36 pm ] |
Post subject: | |
Mario posted while I was reading. |
Author: | Rod True [ Tue Nov 20, 2007 5:37 pm ] |
Post subject: | |
David (and all), Lee Valley also has 1/2" to 1/4" adaptors if you need one of those too. |
Author: | David Collins [ Tue Nov 20, 2007 6:17 pm ] |
Post subject: | |
Man I'm slow today. I searched every machinist supply house, but for some reason my tired brain never thought of looking at any woodworker stores for router accessories. I've been rebuilding an old compressor, looking at grinders, a lathe, and just cutting more metal than wood this week. My brain is just stuck in machining lately and thinking in R8 and 5C collets instead of routers. Duh.... |
Author: | Arnt Rian [ Wed Nov 21, 2007 1:20 am ] |
Post subject: | |
I use the 1/4" to 1/8" adapter from Stewmac too. Never had a problem with it. |
Author: | Michael Dale Payne [ Wed Nov 21, 2007 1:23 am ] |
Post subject: | |
[QUOTE=David Collins] Ken, if you want a good flex-shaft tool, just get yourself a Foredom. It's an investment you won't regret in my opinion. [/QUOTE] Ditto!! and with many different had pieces available they are easy to adapt to different tasks and the ease of changing hand pieces is convenient to assigning hand pieces to specific jigs. I have Stewmac's hand piece for inlay routing #30 chuck three point chuck style handle for bits, larger burrs, grinding stones and cutoff wheels. I would be lost with out my Foredom |
Author: | James W B [ Wed Nov 21, 2007 10:47 am ] |
Post subject: | |
I haven`t had any trouble with the adapter I got from Stew Mac.I`m also using the same Ridgid Router that Todd is. James |
Author: | Howard Klepper [ Thu Nov 22, 2007 7:39 am ] |
Post subject: | |
I'm happy with the Hertel spiral end mills I get from J&L Industrial. I think (not sure) I got the 1/4-1/8 adaptor from them too. Cheap and effective--no slipping. |
